TractorLinks.com
Serial number location on Super Major
buddy04
01-31-2011 11:36:20
I have a Fordson Super Major/5000 that I am restoring. I believe it is a 1963. Where should the serial number be located. I have looked everywhere with no luck. Thanks for the help
KFD68
07-19-2012 14:05:04
 Re: Serial number location on Super Major in reply to scottd, 01-31-2011 11:36:20
If you post your casting number[s] off the gearbox, or back axle, I can date the tractor acurately for you
KFD68
02-05-2011 10:19:19
SuperMajor61
02-01-2011 20:43:30
 Re: Serial number location on Super Major in reply to buddy04, 01-31-2011 11:36:20
KDF68 is spot on ! On a Super the serial number will be found at the right front side of the block where it joins the cylinder head, this will be a raised flat surface. This is not the case with the regular Major nor the Power.
Bendee
02-03-2011 21:02:33
 Re: Serial number location on Super Major in reply to SuperMajor61, 02-01-2011 20:43:30
Not the case with my Super Major,I have the flat area without numbers, I suspect it is down near the starter motor somewhere,something to do.
buddy04
02-03-2011 10:33:31
Thanks for the help. I was unsure if the serial number located on the motor was just the number for the motor or for the entire tractor. Thanks for clarifying.
Chris Don
02-01-2011 17:55:42
I beleve it is located on the right hand side of battery box when you are sitting in the seat.The panel that is between battery and fuel tank.
KFD68
02-01-2011 15:00:35
Lift up righthand side hood. Look at the front side of the block where it joins the cylinder head.
Flat area about 2 inch long x 1/2 inch deep
Serial number stamped into the face you may have to clean the dirt to read it
post the number on here and I will date your tractor for you.
If you want the date of build, post the casting numbers off the block; gearbox & rear axle.
wolfman
01-31-2011 17:21:36
Raise the hood, look up around the battery box.
