Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Fordson Tractors Discussion Forum
Topic: Major Bull Gear Bearings
[Return to Forum]
Scott in PA
01-27-2011 11:00:47
174.55.164.55
Hi All,
I need to replace the bull gear bearings. Does anyone know where I can get them? New Holland has a listing for them but they show that they are no longer serviced. I old ones have SKF part numbers but SKF themselves can't seem to find a match as the number are old and no longer used. I am getting really desperate after a month of searching with no luck. I would even settle for a used ones in good shape.
[Reply]   [No Email]
Mike Farmer
02-07-2011 03:02:45
86.31.10.158
Re: Major Bull Gear Bearings in reply to Scott in PA, 01-27-2011 11:00:47
Hi. I don't know what stage you now reached but I've been trying valiantly to reengage my brain. Thoughts are.(If you cant get correct bearings)
1. Your suggested shim should work. Or have 2mm groung off the back of the cup, the roller bearing will still fit in but it will protrude 2mm toward the wheel. Or just put the overwidth bearing straight in. At worst it means your bull gear will stand proud(overlap) by 2mm and I cant see any thing which that would foul and you will only lose about 2-3% of driving surface contact. MTF
  [Reply]  [No Email]
Scott in PA
02-09-2011 06:42:24
174.55.164.55
Re: Major Bull Gear Bearings in reply to Mike Farmer, 02-07-2011 03:02:45
Thanks Mike. It seems we are thinking the same. The bearings i found are $87us each which is a lot better than $180+ for the correct ones. I struck out in trying to find used ones. One local place just wanted to sell me the whole tractor. I think they are liquidating their salvage yard. Depending on the year and condition i might just go ahead and buy the thing for spare parts.
I am going to order the bearings and then do a test fit to see how things come together. 2-3% loss of surface should make any difference. Most of the time i will be using the backhoe part of the tractor and won't be farming with it. I'll post my results when I have it figured out.
  [Reply]  [No Email]
Mike Farmer
02-03-2011 08:50:50
81.107.135.193
Hi. You may not like what you're about to hear so hold on to your hat. These bearings are available but in extremely short supply. Cost each £130.00 thats about $210.00. If you are still interested I'll send you the address of my contact and you can deal direct that way you won't have to pay UK tax????????. I should imagine with shipping you're not going to get a lot of change out of $500.00. Or you could try Keith at Cotswold Vintage Tractors for good used ones. www.cotswoldvintagetractors.com he's a genuine guy, indeed he may have some new ones. I've now run out of ideas but if anything comes up I'll contact you. MTF
  [Reply]  [No Email]
Scott in PA
02-03-2011 10:05:43
174.55.164.55
Re: Major Bull Gear Bearings in reply to Mike Farmer, 02-03-2011 08:50:50
Thanks again for all the help Mike. I just sent a email to Keith inquiring about used ones. I checked locally for used ones but no one has any that have been removed and the condition of ones in the few Majors (about 3) that are in the salvage yards is unknown and no one really wants to check for me. I honestly can't blame them. It is a lot of work especially in the snow and ice we have right now. I'll wait to hear back from Keith, but I am leaning towards trying one of the Timken bearing that I found (see my post from yesterday). I found a place that has them for about $86us.
  [Reply]  [No Email]
Scott in PA
02-01-2011 19:01:38
174.55.164.55
I have been scanning the Timken and SKF catalogs and found a bearing that is the exact ID & OD but it is about 2mm wider than the original. The SKF bearing # 30218 J2. is I am thinking about ordering one to see if it will work. There should be enough "play" in the bull gear to pinion mating to compensate for the extra width. I could always make some shims to shift the axle housing outward 2mm. Thoughts?
  [Reply]  [No Email]
jkilmer83
02-01-2011 11:26:56
98.144.2.102
another option is to find a local supply house and bring the bearing in to them and they can set you up with a new bearing. The old numbers might be totaly useless.
  [Reply]  [No Email]
Scott in PA
01-30-2011 07:19:03
174.55.164.55
Thanks Mike
Here are the numbers that are the pieces:
Cup - K69630 BH - the opposite side has N-4222B
Cone - K69354/4 - BH24 the opposite side has N-4221
There is also a 1119099 stamped into the cage.
The dimensions are:
Cone ID - 3.5433
Cup OD - 6.2992
Bearing width - 1.1811
If you run the Fordson number through either the SKF or Timken online cross reference, it comes up with a bearing of the correct dimensions but it is a ball bearing and not a tapered roller.
  [Reply]  [No Email]
Mike Farmer
01-30-2011 11:15:57
86.31.212.240
Re: Major Bull Gear Bearings in reply to Scott in PA, 01-30-2011 07:19:03
Ok I'll look into that tomorrow. Did you know that Timpkin offer a remanufacture and repair service. I dont know the details but it might be worth looking into and considering. MTF
  [Reply]  [No Email]
Mike Farmer
01-29-2011 08:38:30
86.31.26.3
Hi. Whats the SKF No. I'll check it out this side of the pond for you. MTF
  [Reply]  [No Email]
lonzo
01-28-2011 17:19:11
216.106.26.196
I got my outer bearings a Baum Hydraulics in Omaha. you half to own a repair shop before they will talk to you. When my transmission bearings went out i couldn't fine any that i could aford, i got bearings that the OD and width were the same but the ID was bigger than the shaft i made adaptors to presson on the shaft them pressed the bearings on the adaptors. that was 4 years ago and i use the tractor all the time and no problems. I think my bull gear bearing are barrel shaaped in stead of tappered, if so you can convert your bearing to tapered kind and do away with the old style. My local salvage yard has 3 or 4 majors laying around so i plenty of parts
  [Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
