Topic: Re: Fordson F Manual
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| Maine Fordson
12-31-2010 14:01:08
74.75.196.56
I'm a little confused; do you have a Model F tractor with a Model N magneto, or do you have a Model N tractor and a Model F manual?
If you have a Fordson Model F, spark plugs are readily available. You can use any ½" pipe thread spark plug:
A lot of old-engine people use an Autolite 3095. Folks like the one-piece Autolite 3095 because they are inexpensive. If you buy a box of 10 they are around $3 or $4 each. But their porcelains are not glazed so they are harder to clean.
Another suitable plug is the Motocraft F-11.
The AC Delco 26 will work if you can find one, but they’re no longer being made.
The Champion X was the plug designed for the Fordson tractor and Ford Model T automobile, and works fine but it has smaller ground and center wire. You can still buy these "X" plugs from Champion, but they're about $25 apiece, so save them for show unless your wallet's a lot fatter than most of the folks on this board.
All of these are ½" pipe thread. There were a lot of ½” NPT plugs on the market in the teens and '20's: Bethlehem, Blue Streak, Defiance, Oil-Rite, Red-Head, Sootless, Wards, and tons of others. This same plug is used not only in the Model T and the Fordson Model F, but also in the Deere Model D from 1924-30, some Maytag washer engines, and who-knows-how-many other gas engines from those days.
Interestingly, this ½” NPT plug has quite a history with Champion: originally it was the Champion No. 7. However, this was before Champion etched the plug’s identification number on the insulator (with a few exceptions), so they are hard to find. In September of 1929, they began printing the number on the plug’s porcelain, and “changed the No. 7 to the No. 31”. So, you can look for Champion 31 plugs - they are 2-piece take-apart plugs and come in different styles – the earlier ones have wide brass hats, the subsequent ones don't. Later, the Champion 31 became the A-25, then the 25, and now apparently it is being called the 525. (Not sure, since I’ve got a bunch of new or nearly-new plugs on the shelf in the machine shed and haven’t bought any in quite a few years; I just clean the old ones – but more on that in a minute...)
One important thing to note: shortly after Champion renamed the No. 7 to the No. 31, they started using the number 7 for an 18mm plug used in automobiles, and they are pretty readily available. So, it is very common for people to say they have Champion 7 plugs – and some of them apparently don't know the difference between a ½" pipe thread plug and an 18mm plug…
Also, Champion’s line of plugs often has the word “com” (short for their “commercial” line of spark plugs – often they have dual grounds and heavier center wires; this was supposed to prevent fouling, but the idea didn't work out as well as intended in practice). A common Champion 7/8-18 plug is the “2COML” plug, which figures out to a Number 2 plug, commercial L(ong) version.
Keep an eye on eBay for Champion 31 plugs – they do show up occasionally, but bring your wallet -- they seldom sell cheap.
As for cleaning these “take-apart” plugs, the first time you disassemble them may be a bit of a challenge, as it’s probably been a while since those threads turned. (When you re-assemble, use a bit of the copper-based anti-seize to help you out the next time you take it apart.). Separate all the parts, then clean the plug body with a wire brush or wire wheel. Be careful of the internal copper washer/gasket. If necessary (and it may very well be the first time you do this), scrape off heavy carbon deposits with a knife blade. Don’t damage the glaze on the porcelain if you scrape it. I would advise against using the wire wheel or brush on the porcelain insulator, as the wire may leave behind minute bits of metal which may cause you trouble later on. Best way is to bead-blast the lower part of the porcelain. (If you’re making a “show plug” you can also take the time now to polish the brass pieces.) Make sure everything is very clean before re-assembly.
Re-install those plugs, attach the ignition wires, lift the starting handle and listen to her purr!
-- Maine Fordson |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
