TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson E27N serial number
cdmn
12-29-2010 20:37:31
The serial number should be on a metal plate attached to the front of the firewall. It also could be stamped on the engine block toward the front, just below the head gasket, or on the bell-housing near the starter.
6015 was Ford's casting number for engine blocks. The E27N in front says it was for the E27N. Other numbers might relate to the date of pouring or the ID of the wooden casting pattern. (They probably had many duplicates)
Rowan
12-31-2010 09:10:46
 Re: Fordson E27N serial number in reply to cdmn, 12-29-2010 20:37:31
Thank you, sorry to ask so many questions but where is the firewall?
cdmn
12-31-2010 20:04:02
 Re: Fordson E27N serial number in reply to Rowan, 12-31-2010 09:10:46
Sorry I was thinking New Fordson Major. On the E27N, the plate is on the rear fuel tank support, facing the front.
Rowan
01-02-2011 05:38:46
 Re: Fordson E27N serial number in reply to cdmn, 12-31-2010 20:04:02
Thank you, I'll have a look.
Rowan
01-08-2011 10:05:33
 Re: Fordson E27N serial number in reply to Rowan, 01-02-2011 05:38:46
On the rear fuel tank support, on the left at the front side, i found a bolt on plate. On this, it said Fordson tractors, high speed top gear and a number. I thought this number would be 6 digits but it is seven, is it the serial number? Her is the number... 1090848
Mike Farmer
01-08-2011 11:25:01
 Re: Fordson E27N serial number in reply to Rowan, 01-08-2011 10:05:33
That No makes it 1948. I dont have enough info to date it more precisely than that. However if you wish to play guessing games then:- 1st E27N of 1948 was #No1054094 and the last was #No1104656 so at a straight guess I would say yours is Mid to end October 1948. But that really is just a guess. The High Speed Top gear is a 7.8:1 ratio.(The Low Speed was 4.9:1)For their time they were reasonable tractors but they were seriously hard work to use all the engine weight right down on the front axle and no power steering.I used one recently and it nearly crippled me just to reverse a trailer into the barn.Good Luck MTF
