| Fordson Tractors Discussion Forum |
Topic: Tach and 2 lights in the cluster
[Return to Forum]
| Author |
[Modern View]
| Hillrie Rouse
12-29-2010 11:49:38
64.12.116.199
I just bought a 1958 Fordson Dexta and am wondering about the two lights in instrument cluster There is one on each side of the tach the right hand one blinks and I am concerned about it. Any help will be many thanks |
| Jeff NWOH
01-02-2011 10:00:27
71.72.102.75
Re: Tach and 2 lights in the cluster in reply to Hillrie Rouse, 12-29-2010 11:49:38
| | The right hand light is supposed to be for oil pressure. Should be green. The red on the left is for charging. Assuming yours is diesel, the sender is on the left side of the engine close to the injector pump. Remove the sender and plumb in a manual gauge to see if in fact you have an oil press problem. Think i had to use an elbow to make it work. I repaired the light on mine and then it stayed on all the time. I actually had around 60 psi oil pressure, so I got a new sender from NAPA. They do go bad. Hope that's all thats wrong with yours. Jeff |
| Robert Major
12-29-2010 16:16:36
216.130.77.241
| Ok on the dexta you have an oil pressure light for the engine and a charge light for the generator. I think the red ones oil and greens gen but cant remember it"s 20 years ago since i drove one. if its the gen one it just means something maybe is wrong with the charging system. if it"s the oil one it either means the sender is faulty or you may be heading for a bang with no/ low oil pressure. try and figure out the wiring locations to see whats connected to what. if its the oil one try and fit a test gauge and see whats going on. you need to know for sure on oil pressure or faulty switch. No pressure x Big Bang = Huge Bill! I"m a full time mechanic and see the guys faces that ignore flashing lights when I give them bills for motor re builds. Good luck and I hope its a switch or charge light. Regards Robert |
| Hillrie Rouse
12-29-2010 17:03:53
205.188.116.199
Re: Tach and 2 lights in the cluster in reply to Robert Major, 12-29-2010 16:16:36
| I did not have the light come on until I changed oil in it---I went with 30 wt and ran for a while and the light started blinking--------What if any thing this had to do with it? I saw where if it had always had non detergent oil to not use hd? Help?-------Could this have something to do with it? |
| Robert Major
12-29-2010 18:29:11
216.130.77.241
Re: Tach and 2 lights in the cluster in reply to Hillrie Rouse, 12-29-2010 17:03:53
| Maybe it had thicker oil in it at the start and it now has thiner oil that would increase clearances when hot. if high detergent oil is used in old motors it scrubs the old gunk out of the motor and plugs the suction screen in the oil pan and oil filter, causing low oil pressure. if the old oil was like tar and the new is like water the oil pump crank and all the bearings could be worn. you need to get an oil pressure gauge on it and see whats going on. or put thicker non detergent oil in and run it to see if it cures it. The worst option is theres low oil pressure which means the motors up for rebuild and to be honest a tractor of that age with poor previouse owner maintanence could be needing it. Thats the best I can tell you without seeing the tractor and doing some test work on it. Regards Robert |
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
