TractorLinks.com
Fordson Tractors Discussion Forum
Super Major Camshaft
Scott in PA
12-16-2010 12:40:11
Hi All, I am working on rebuilding the engine for my Super Major and I noticed that there are no camshaft bearings. This is puzzling to me as I am use to having bearings in the car/truck motors I have done. What do you do if there a grooves from dirt? New camshafts for the Majors and Supers seem to be few and far between and the ones I did find don't show option for oversized journals or even retro-fit bearings. Do I just clean and lube it well and leave it alone or what? I want to take the block, head, and crankshaft to the machine shop in the next couple of days and need to know what to tell them about the cam.
Thanks in advance.
Scott in PA
12-29-2010 12:58:46
 Re: Super Major Camshaft in reply to Scott in PA, 12-16-2010 12:40:11
I think I am going to buy a new cam. It would make me feel better. The problem is that I have the old three bolt gear. Anyone know where I can get one of the one bolt gears? Agriline doesn't have them.
Mike Farmer
12-18-2010 03:55:00
Hi. I've just had a good read about this and 'the book' says quote "If cylinder block is not fitted with bushings and camshaft bores are excessively worn, bushings can be installed after line boring all five bearing bores in the crankcase.
For engines originally fitted with bushings-new and new oversize bushings are available.
I will now have a dig around and see if I can find some for you. MTF
Mike Farmer
12-20-2010 03:22:45
 Re: Super Major Camshaft in reply to Mike Farmer, 12-18-2010 03:55:00
Sorry I am not able to find any replacement cam shaft bearings. I will keep looking. New camshaft is available from 55 up.Try www.southerntractorspares.co.uk MTF
The Swanndri Guy
12-16-2010 22:03:32
Scott, you might want to have a look at the "New Major" forum on "www.fordsontractorpages.nl"If you can find oversized camshaft bearings, there would be a lot of other people wanting them too.TSG.
