fitting a loader
Do you have external hydraulic ports?
Fitted one on my MF135, had to get the little box that fits in place of the cover that goes over the standpipe from the Hyd pump at top of the Hyd cover, not sure if your ford is the same.
From port on diverter vale piped to a spool valve to operate loader, as gives you much more sensitive control. The one drawback with the diverter valve is you cannot operate front loader and back hydraulics at same time as you have to isolate one or the other.
Kenneth
