Draft control adjustments Ford 860
phil slocum
New User
I replaced some internal , plunger, freed up the un-loader valve, and cleaned up 50 years of rust. The service manual calls for special tools to adjust the linkage, our local dealer does not have these tools, one holds the 3 pt lift arms in a fixed position and the other is a gauge to set a gap on the linkage. Has anyone got any idea ow to do this with out the tools, the book gives no spec for the gap or measurement as to where the arms are to be when the gap is set.
You may want to post this on the Ford board if you haven't already. Zane Sherman does a lot of stuff with the Ford hydros. His site is below. He usually lurks about in the N Forum and Ford Forum. A wealth of info and always willing to help.
Zane Sherman
