major deisel hydraulics
There are several troubleshooting steps to be done here, given that no other details were given.
1.0 is there enough hydraulic fluid in the tank?
2.0 When last was it changed?
3.0 Hydraulic filter clogged?
4.0 Are there any leaking hoses?
5.0 having finished the easy stuff, what is the condition of the pump?
regards
Marlon
Ford Tractor Parts
changed oil in hydraulics cleaned screen 3 point works awsome lifting heavy objects but only 2-3 ft up then stops.unloaded goes up and down with no jerks or stops next check is pressure gauge.seems like relief valve maybe?
barely lifts anything over 200 pounds.cycles all the way up smoothly drops down smooth not really fast.
