Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Re: FSM Camsaft Timing Gear Removal
Scott McCoy
11-07-2010 06:08:46
The tractor is a '64 but the engine is a '57 or '58. The number 3 c-rod went out the side of the original block. So it is a older 3 hole pulley. I tried hitting the center bolt of the puller (a trick that usually works) but it wouldn't budge. I'll try hitting the pulley tomorrow with a dead blow hammer, with the puller tightened up and see if that work. I did strip the original motor so i have the new style pulley to put on after the re-build.
cdmn
11-07-2010 15:13:19
 Re: FSM Camsaft Timing Gear Removal in reply to Scott McCoy, 11-07-2010 06:08:46
You mean gear, not pulley. Don't use excessive force. You can break out the spokes or hub of the gear. And you don't want to distort the teeth, or they'll make noise and damage the mating gear as well. I found mine was broken, but the hub slid off the camshaft and dowel pin fairly easily.
The older style gear and newer one don't interchange. You need the whole cam shaft as well. And then, there is possibly something about the thrust washer and front plate to worry about. The newer gears are wider as well. They also made service replacement gears with the 3 holes, but thicker. This indicates a problem area.
