Yesterday's Tractor Co. The Right Parts, Right Away
TRACTOR   PARTS TRACTOR   MANUALS
   Allis Chalmers Case Cockshutt Farmall IH Ford 9N,2N,8N Ford
   Ferguson John Deere Massey Minn. Moline Oliver All The Rest
Tractor Manuals
TractorLinks.com
Enter your email address to receive our newsletter!
subscribe
unsubscribe
Fordson Tractors Discussion Forum
Topic: Ford 8700 Minimec Fuel Injector Pump
[Return to Forum]
Carlton Wallace
10-29-2010 09:49:23
155.147.47.68
I tried to crank my Ford 8700 after not using it for about three months and it wouldn't start. Fuel is not leaving the Minimec injector pump at any injector line. Good fuel flow through bleed screw on pump. Could the fuel cut-off be stuck? I have moved the cut-off control back and forth serveral times thinking is might free something up, but no luck. Could the injector pump go bad just sitting there. It was replaced in an overhaul less than 2,000 hours ago. Any ideas would be appreciated.
[Reply]   [No Email]
Mike Farmer
11-09-2010 01:02:32
86.23.4.190
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to Carlton Wallace, 10-29-2010 09:49:23
Glad its running again. Thanks for the feedback about your success. We don't often get that so dont know whats been successful and maybe a different way to go in future. MTF
[Reply]  [No Email]
lonzo
11-03-2010 18:46:10
216.106.26.196
diesel fuel can and does leak from the primer pump on the side of the injection pump. replace the primer pump and you should have no more fuel leaking into the injection pump till the primer pump starts leaking again,,( a few years later )
[Reply]  [No Email]
Carlton Wallace
11-09-2010 05:38:12
155.147.47.69
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to lonzo, 11-03-2010 18:46:10
Thanks again for the advice. Always good to hear about these things from others with experience.
[Reply]  [No Email]
Mike Farmer
10-31-2010 10:14:42
82.26.174.232
I would initially just crack all the fuel lines(in turn at the injectors) and turn it over to ensure fuel flow right through the system. If that dont work then have a go at the side panel etc.Its the simple way to go. MTF
[Reply]  [No Email]
Carlton Wallace
11-01-2010 05:48:01
155.147.47.69
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to Mike Farmer, 10-31-2010 10:14:42
Thanks for the reply. I have loosened the front injector line at the pump and turned the engine, but no fuel come out. I'll try your advice. Thanks.
[Reply]  [No Email]
lonzo
10-30-2010 00:38:25
216.106.48.195
take the side cover off the pump and move the throttle leaver and see if pump rack is moving. i say it won't. if so use a screw driver to pry the rack back and forth. the rack is the bar you can see that has notches cut in it. who knows it could be out of oil.
[Reply]  [No Email]
Carlton Wallace
11-02-2010 07:07:32
155.147.47.68
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to lonzo, 10-30-2010 00:38:25
Problem solved. You were dead on with the pump rack not moving. With it not being used in a while, gunk apparently dried on and prevented movement. I sprayed with carburator cleaner and moved back and forth until it moved freely. The tractor cranked right up after this. I drained the oil in the pump and it appeared diesel fuel had mixed with the oil which concerns me. Is this a sign of wear around pump pistons?
Thanks to all for the help and advice in solving.
[Reply]  [No Email]
Showcrop
11-03-2010 04:57:04
75.67.231.80
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to Carlton Wallace, 11-02-2010 07:07:32
I have a 9000 that leaks fuel into the pump so that it starts to come out the overflow tube in less than 10 hours. I have been told that it means a leaking seal and is not unusual and doesn't hurt anything. Since it runs OK I just drain some off and add some new oil periodically.
[Reply]  [No Email]
Carlton Wallace
11-09-2010 05:42:56
155.147.47.69
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to Showcrop, 11-03-2010 04:57:04
Thanks for replying. I just changed the oil and will continue to watch and changed more often.
[Reply]  [No Email]
Carlton Wallace
11-01-2010 05:53:30
155.147.47.69
Sounds logical. I was wondering what had to be done to see if the rack was moving. Thanks for the help lonzo.
[Reply]  [No Email]
sd pete
10-29-2010 14:25:25
24.230.139.54
I used to have a 9700. Did you try pushing the fuel button on the shut off lever at the pump. Could crack a couple of injector lines too. Just a couple of ideas that don"t cost much to do.
[Reply]  [No Email]
Carlton Wallace
11-01-2010 06:02:18
155.147.47.69
 Re: Ford 8700 Minimec Fuel Injector Pump in reply to sd pete, 10-29-2010 14:25:25
Yea I tried that first. In my experience with Fords in the past, that usually will always take care of it. Thanks for the reply.
[Reply]  [No Email]
[Options]  [Printer Friendly]  [Return to Forum]   [Add a Reply]
Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F).  Expedited shipping available, just call!  Most prices for parts and manuals are below our competitors.  Compare our super low shipping rates!  We have the parts you need to repair your tractor.  We are a Company you can trust and have generous return policies!   Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ]
Copyright © 1997-2013 Yesterday's Tractor Co.
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
