Anonymous-0
Hello,
Was wondering if there was any way to adjust the governor responce on the simms injection pump. It is on an industrial for engine that is the same as the one in a major.
The problem is that it idles too low when cold and too high when warm. Its on an aircompressor and I've adjusted the idle, but it stalls when going to idle because of the load. If I adjust the idle up it will work fine cold, but idle to high when warm and blow the air pop off valve when warm....
Thanks
Thanks
