Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Fordson mag
h1308
09-28-2010 10:28:41
Does the flywheel mounted mag on the Fordson F put out DC or AC current?
cdmn
09-28-2010 21:06:29
 Re: Fordson mag in reply to h1308, 09-28-2010 10:28:41
AC
h1308
09-29-2010 05:11:22
 Re: Fordson mag in reply to cdmn, 09-28-2010 21:06:29
So the coils,etc, will operate off AC (mag) or DC (battery) equally well?
Theman
09-29-2010 08:19:04
 Re: Fordson mag in reply to h1308, 09-29-2010 05:11:22
Yes, pretty much. Just not at the same time. My '23 F actually runs a little better on the mag putting out 10 to 13 volts A/C than the 6-volt battery that it starts with.
As an aside, if you want to see something unusual and have access to one, hook an oscilloscope up to it. Henry put the 'form' in waveform.
h1308
09-29-2010 08:40:22
 Re: Fordson mag in reply to Theman, 09-29-2010 08:19:04
Thanks for the information. Now a question about my 14 Ford T (same system). It will no longer run on the mag. Any problem with running it continuously on the small 12 v battery I use to start it?
Theman
09-29-2010 13:37:39
 Re: Fordson mag in reply to h1308, 09-29-2010 08:40:22
No problem. Just disconnect the flywheel magneto lead so there's no additional drain from the coil assembly.
Copyright © 1997-2015 Yesterday's Tractor Co.
