Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
1964 FSM Won't start after running out of fuel
Jack Messing
09-28-2010 05:53:52
Howdy Folks,
Was out using the tractor and it was running great till I ran it out of diesel. Filled the tank and now it cranks but won't start. Runs with starter fluid only. Tried the excess fuel lever but still won't go. Any Ideas where to go next? Thank You
Jack Messing
10-07-2010 06:21:13
 Re: 1964 FSM Won't start after running out of fuel in reply to Jack Messing, 09-28-2010 05:53:52
Thanks for all the replies. I got it going just fine. It needed to have the air purged at the injector pump. The operation manual had it described. The spring loaded lever on the fuel pump is a mini pump and just loosen the plug on the injector pump. (manual has a picture)
ninenailz
10-04-2010 11:45:56
Start by bleeding the air out at the Fuel filter, then go to the injecter pump. There should be a pump on the bottom of the sediment bowwl that will pump fuel through the sustem.
kenneth armour
09-28-2010 18:10:38
Hi:
You need to bleed all the air out of the system.
Once the fuel system has air it will not start
The manual will show you how.
Kenneth Armour
rustyj14
09-28-2010 07:29:18
One of our diesel fired Fire Trucks ran out of fuel one day, and to get it back to running condition, we had to prime all of the fuel lines, the fuel filters, and some other things. Don't ask me what, as i know next to nothing about diesel engines, except for the need to reprime the fuel system. HTH:Rusty Jones
Copyright © 1997-2015 Yesterday's Tractor Co.
