| Fordson Tractors Discussion Forum |
Topic: Re: Model F Model N parts interchangeability?
[Show Entire Topic] [Return to Forum]
| Author |
[Modern View]
| SteveWelker
08-24-2010 05:31:45
74.93.122.41
Yes, a Model N engine will bolt to the Model F, but it is not that simple. First from the pictures in your earlier post, the F is a late 1925/early 1926 and is indeed very original. I can even see the original style rolled fuel line with a seam! I can tell the year by a couple features, Mag kill switch on dash, flush plug head w/o bosses for plug wire holder, Holley 295, Rolled lip front wheels, Rear wheels drilled for both left and right cleats. A few main problems/issues to install the N engine. First, if you intend to use the N head and water pump, you should also use the N radiator or at least the side castings, as the N fan is in a different location and the cutouts in the radiator sides are different. You could use the F radiator if you use the F head on the N motor w/o the water pump, but the '25/'26 head does not match the water oppenings of the N block exactly. I have seen them used but they can leak. A '27/'28 F head (p/n F133C or F133D) will match the N block exactly. Second you will need to use the N style front cover as it is made for the Mag and governor. If this is the English N front cover with the bolt pattern for the rowcrop pedistal, you can use you F front axle, If it is the Irish/English N front cover with the long axle support, you will need the dipped Irish front axle to keep the tractor level. Third, because the N engine has the 'dropped' manifold ports, the throttle linkage will not line up with the hole in the '25/'26 F dash. A '27/'28 F dash will work as these were also dropped port engine, but with the F dash you can not use the N governor without cutting a hole in the dash for the pull style throttle. If you have an Irish N dash this will also work and allow the use of the N governor. An english N dash has a long steering column, and would require the rear seating position and also the English rear housing with the clutch behind the axle. This is all probally very confusing, but what I am trying to get at, is it complicated, and unless you been around these fordsons for years, you will run into some problems with this swap. This all being said if I was buying these 2 tractors (Complete non-running F, good N motor) this is what I would do. Take the Good N internals and put them in the F block. The N valves are a larger stem size which would alow the F guides to be opened up, and the N pistons are an 1/8" bigger bore which would allow a rusted block to be rebored and cleaned up. I would even use the N Crank and Rods if they were in nicer shape. In the end you would have an original looking tractor that is worth more than a 'half-breed' F/N. Good luck, if you have any questions let me know. -Steve |
| SteveWelker
08-24-2010 06:42:40
74.93.122.41
Re: Model F Model N parts interchangeability? in reply to SteveWelker, 08-24-2010 05:31:45
| One added note. Any N model will be rarer than a '25/'26 F here in the USA. They made 174,470 model F's in just the 2 years 1925 & 1926. The Irish N models are very rare as they had a very low production, only a little over 28,000 in 3 years. They made 61,760 English model N's over the 7 years they they were imported to the USA. These are total production numbers on the model N's, but a fairly low percentage of these were actually imported to the USA, most stayed on the other side of the pond. So you may consider restoring the N. Or get both and have one of each! When colecting old fordsons, its hard to have just one! -Steve |
| [Show Entire Topic]
[Options]
[Printer Friendly]
[Return to Forum]
[Add a Reply]
| Same-Day Shipping! Most of our stocked parts ship the same day you order (M-F). Expedited shipping available, just call! Most prices for parts and manuals are below our competitors. Compare our super low shipping rates! We have the parts you need to repair your tractor. We are a Company you can trust and have generous return policies! Shop Online Today or call our friendly sales staff toll free (800) 853-2651. [ More Info ] |
Home
| Forums
Copyright © 1997-2013 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor Headquarters |
About this site - Yesterday's Tractors is your one-stop source for antique tractors. If you are interested in older tractors you've come to the right place! Join more than 275,000 other classic tractor enthusiasts from all over the globe. We have many resources for antique tractor enthusiasts available including photos, classified ads, more than 24 tractor discussion forums, a show guide, values, specs and much more. Bookmark this site and come back often. Thanks for stopping by! Feel free to use our feedback form to send us your comments, suggestions and ideas.
