Anonymous-0
The 58 new major that i have is giving me serious fits. I just bought this not to long ago and it didnt run quite right so i sent the injectors out to be cleaned. Two of them were sticking bad according to the mechanic. There good now. I put them in and tried to start it today after bleeding very well. Wouldn't start so i took a look at the injection pump and the timing was off. I reset it as to specs from manual and i fired up. Seemed to be running on all cylinders. Has alot of white fuel smoke at idle but idles decent. When you give it throttle it would pour the white smoke and takes forever to pick up rpm if it even does. I have took the pump inspection plate of for a brief period to see if everything was moving good and it is. I tested the vaccum governor like the book says to and it shows good. The adjuster for the injection pump that people so much like to crank up for more power has the safety wire cut like someone has messed with it before. I talked to a mechanic and he said it might just be to far out of adjustment for it to run right. So i messes with that a little and had no cignificant changes in the way it ran. Then it just got worse and would not change at all. I set it back to where it originally was and it runs terrible now. Takes a little shot of ether to get it to start. Wont run for more than a minute on its own. And wont even pull the tractor in first gear. What have i done what could be the problem. I would really appreciate and help you guys have. Thanks a lot
