TractorLinks.com
Fordson Tractors Discussion Forum
Re: !953 Fordson Major, cracks in between liners
tiresntracks
07-19-2010 02:02:08
Are the cracks only on the top of the block and in the top counterbores for the liners? If so, it will be ok. There are no o-rings in the top of the liners and the head gasket is the only thing that seals them. It will seal the cracks, too. I have one that's been running like that for several years.
If the cracks go all the way through the liner o-ring grooves in the bottom of the block, its time for another block.
Robert Rengler
07-19-2010 18:04:05
 Re: !953 Fordson Major, cracks in between liners in reply to tiresntracks, 07-19-2010 02:02:08
They go in between the liners, and both blocks I have have similar cracks in similar aeras, except for the one I brought, It is cracked also in Right Front from liner to outside and about halfway down the block. So your suggestions is to remove the liners and see how far the crack goes down inside is that correct.
tiresntracks
07-27-2010 23:18:46
 Re: !953 Fordson Major, cracks in between liners in reply to Robert Rengler, 07-19-2010 18:04:05
I usually look at this BB every day, but I've been busy and haven't been on here for a while.
The block with the crack that runs to the outside sounds like its probably junk. Pull the liners out of the other one and see how far down the cracks run. If they don't go through the o-ring grooves, its probably still usable.
Robert Rengler
07-28-2010 05:47:13
 Re: !953 Fordson Major, cracks in between liners in reply to tiresntracks, 07-27-2010 23:18:46
Thank you for the Heads up, I am getting maybe another replacement Engine, But I am alos thinking of taking main engine apart and further inspect it
