it has come to my attention that I could use a new set of injector lines. I made a repair several years ago on the #4 line and today it quit and of course sprayed fuel every where before I could get the tractor back to the shed. The day was exciting because my simms minmec tried to let the engine run away... twice. must need oil again. if I turn it off and restart thing are ok .. for a while must be the governor which is NOT vacuum on this tractor. so the question is - is agriline the only source for new fuel lines? thanks and what is the BEST way to see about the pump? it seems to get funky when the tank is low
