1963 ford super major 5000
hey guys I have what I have believed for yrs is a 1963 super major 5000, can you determine by the number on the block,E1ADDN 6015,,, I am listing it on enbay as i dont use it too much anymore and wanted to listr it correctly, thanks,pat
here are a few pics
It looks like a New Performance Super Major, which was also called a 5000, in the US. The number in the picture was cast into all diesel Major blocks. The serial number is stamped on the block, below the front injector. It should start with 08C if its a '63 or 08D if its a '64.
(quoted from post at 07:14:46 06/14/10) It looks like a New Performance Super Major, which was also called a 5000, in the US. The number in the picture was cast into all diesel Major blocks. The serial number is stamped on the block, below the front injector. It should start with 08C if its a '63 or 08D if its a '64.
thanks tiresntracks, I appreciate the help, I found the serial number I guess it is actually a 1964 wow a "new" tractor. Thanks again,pat
