Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
Fordson Tractors Discussion Forum
Fordson Super Major?
Jack Mayers
07-14-2010 19:06:18
I just purchased a 1961 Fordson Super Major with a Ford series 712 backhoe/loader. At least I was told it was a 61 Super Major. Every picture I have found of a Super Major the frame from the radiator area going back to the transmission is a straight C beam just like my 57 Major Diesel. My Super Major"s frame curves down then straight back to the trans area. Was there an industrial version of the Super Major, or is this something else? I"ve posted a picture to illistrate. I"ve been looking for a power steering kit for it but not sure what to get.
Any feedback would be great.
Thanks,
Jack
woodache
08-06-2010 06:40:56
 Re: Fordson Super Major? Drop Frame Industrial in reply to Jack Mayers, 07-14-2010 19:06:18
This was used on the factory installation of or setup for Industrial B-Hoe Loaders. You also may want to check the front axles for a installed 1" thick about a foot long (welded) cap over the rocker pin. You may also have a 3/4" thick extra piece of steel , that runs the full width of the casting bolted to the back of the lower front cast base that has the mounting for the rocker pin hole. If it has that it will also include a extension of the frame mounted bushing for the rocker pin.
I have one of these tractors, I have seen others just the same.
Shetland Sheepdog
07-19-2010 06:16:59
 Re: Fordson Super Major? in reply to cdmn, 07-14-2010 19:06:18
If I'm seeing correctly, the curved frame is the loader sub-frame, not the tractor frame!
The Swanndri Guy
07-14-2010 23:49:19
 Re: Fordson Super Major? in reply to Jack Mayers, 07-14-2010 19:06:18
Whats the serial number? Super Majors serial number start at 1578886, 22 Nov 1960. Super Majors have disc brakes,diff lock and improved hydraulics compared to Majors.TSG.
Jack Mayers
07-15-2010 18:01:50
 Re: Fordson Super Major? in reply to The Swanndri Guy, 07-14-2010 23:49:19
I'll check for the serial number. I won't be able to for a of weeks but I'll post it when I get it.
Thanks,
Jack
