TractorLinks.com
Fordson Tractors Discussion Forum
Re: 3 point hitch will not work
dss7
06-24-2010 10:51:04
Right, he is filling it through the top with the cover off. The actual fill plug is close to the same height as the cover on the system. If you filled it to that level it would be to the top, therefore over serviced. I"m looking for the location of the "check level" plug.
terry274
06-24-2010 12:46:20
 Re: 3 point hitch will not work in reply to dss7, 06-24-2010 10:51:04
The fill level plug is on the left side behind the clutch pedal. It is a square plug. Do not remove the hex head bolt on the right hand side, it holds the oil filter on and you will have to take the cover off to replace the nut on the end of that bolt.
Terry
dss7
06-27-2010 15:08:20
 Re: 3 point hitch will not work in reply to terry274, 06-24-2010 12:46:20
Found it. Thank you for the help. Was a little low on fluid. Topped off but lift still will not work. Guess it's time to take the cover off.
