Yesterday's Tractor Co.
Shop Now View Cart
Fordson Tractors Discussion Forum
Re: 3 point hitch will not work
06-24-2010 06:47:14
What do you mean by plug level?? I know where the fill plug is but haven"t been able to tell about the level plug. Thanks for the other information.
06-24-2010 07:58:17
 Re: 3 point hitch will not work in reply to dss7, 06-24-2010 06:47:14
He means he has the lift cover off and can see inside to the fill level plug. He pours oil in until he reaches this level.
06-24-2010 10:51:04
 Re: 3 point hitch will not work in reply to terry274, 06-24-2010 07:58:17
Right, he is filling it through the top with the cover off. The actual fill plug is close to the same height as the cover on the system. If you filled it to that level it would be to the top, therefore over serviced. I"m looking for the location of the "check level" plug.
06-24-2010 12:46:20
 Re: 3 point hitch will not work in reply to dss7, 06-24-2010 10:51:04
The fill level plug is on the left side behind the clutch pedal. It is a square plug. Do not remove the hex head bolt on the right hand side, it holds the oil filter on and you will have to take the cover off to replace the nut on the end of that bolt.
06-27-2010 15:08:20
 Re: 3 point hitch will not work in reply to terry274, 06-24-2010 12:46:20
Found it. Thank you for the help. Was a little low on fluid. Topped off but lift still will not work. Guess it's time to take the cover off.
