I am completely rebuilding a 1962 Super major. New sleeves,pistons,pins, rings, gaskets,etc. It runs beautifully but leaks water into the cylinders. Tried a second head gasket but same thing happens. On closer inspection head gasket has no "crush marks" from head being torqued down. Protrusion of sleeve above block seems to be in spec(.002-.004). When you put a straight edge across top of sleeve rim it just barely touches head gasket so there is no pressure to restrict water leakage into cylinders. I removed sleeves and checked again to see of rim seat in block was clean and it was. Only thing I can think of is the original head gasket was thicker than what I can get now. Thought about using two head gaskets. Any ideas would be helpful.
