Kerry Borsch
Hey guys,
i stil lneed help with removal of my lift arms on top cover. I have tried wedging a putty knife between cover and arms and pounding with a sledge but no movement. The things seem welded on. I understand the splined tube comes out the right side if your sitting on the tractor,is that correct. I also wonder if the arm on the inside of the cover is held in place with anything other than the splines. I do not see a pin or bolt to hold it. I do not have a press or air hammer gun and will if nesscesary take the cover to the tractor dealer, but I thought i would see if anyone has a trick to popping them off. Thanks for any help. Kerry
