Can someone post Pics of where the motor ID is!
zano
New User
Can someone post Pics of where the motor ID is!I have been told to check the number 1 injector but dont know were it is. Can someone post a pic of were the 1 injector is and were the numbers are and where other ID numbers may be.
Thanks
Its on a flat machined surface below the No 1 injector. It should also be on a makers plate on the fire wall by the battery and it may well also be stamped into the clutch housing somwhere near your right foot (it seems like this was not always done). For a Power Major you will be looking for a No between 1481091 and 1578885. MTF
ok after reading this i have found out that mine is not what i thought it was the numbers under the number 1 cylinder are 1393941 what do i have?
That engine number is for a 1956 Fordson Major Diesel. Are your gages and throttle blow the fuel tank? FMD, Or is the throttle and gages above the tank just below the steering wheel? FPM, FSM. If so, the motor may have been changed at some point which is common.
