TractorLinks.com
Fordson Tractors Discussion Forum
Re: Fordson F Running Miserable
Kornfused
05-15-2010 18:31:00
Sounds like water/bad gas has settled in the carb. Drain out at the bottom of the carb. If you can get a pint of flow in 2-4 minutes out of the bottom of the carb, then you know you have no problem from the tank to the carb. If not, then start with screen in the elbow at the carb and work back twords the tank until you get good flow. If that don't fix it - Put some Seafoam in it and put it to work, long and hard. If you still have problems, you will need to take the carb apart and give it a good cleaning.
