Kerry Borsch
Hi All,
I just took my outer bearings off my axles and noticed the surface area of the small "step up" angle leading to the oil seal/axle surface interface is different between the 2 axles. One is almost twice the surface area. Is that a mistake? The axle seals and housings have the same part numbers. Is this a problem or have any of you seen this? Thanks for any input in advance... Kerry Borsch
