maplehillfrm
ok I went out and took the block off that holds the injector lines,,
[those little hex screws are a pain],, I found that I had a broken spring on #4,, and a broken tab off of the valve on #1,, as well as #1 stuck up ,,,
could the #1 valve being stuck up restrict the fuel from getting to the others full strenght??
I now know why #1 wasnt getting fuel anyway,,
now I need to find a spring and a valve....
any one have a set laying around?? new or used would be ok,
or a place I can get them,, the number on the injector block is P 4596 --then 1A, thanks pat,,
I figure I cant do any more until I get these parts fixed,,k
