TractorLinks.com
Fordson Tractors Discussion Forum
Super Dexta Hyd Pump
Mike5
04-06-2010 07:24:55
Cannot seem to locate a source for a replacement pump. I this available or do I need to investigate the parts required for rebuilding the existing one?
Just purchased a 1962 Super Dexta and the three point hydraulics are not working at all. Have purchased a replacement filter. Will change this first.
Thanks!
DwightD
04-07-2010 15:43:19
 Re: Super Dexta Hyd Pump in reply to Mike5, 04-06-2010 07:24:55
I have one with the same problem. It sat all winter and now the arms won't lift. Where is a filter on this? I have never seen a hydraulic oil filter on mine.
WayneB
04-27-2010 11:52:15
 Re: Super Dexta Hyd Pump in reply to DwightD, 04-07-2010 15:43:19
Gents, Filter will clogg and nothing works. The hydraulic on a Dexta is under the top cover. About a one hour job to change the filter, and two if you let the fluid drain. Takes longer to take the seat off than the cover. Do mine @ every three years now, put a new filter in. Located on R/S tube from housing you can see with top off. Once top is off; loosen one bolt that holds tube, screw replaceable filter (@ $15) and (@ 5 Gl fluid). Replace tube. I filled mine by dumping it in to check plug level-then put the top cover back on. Use a cherry picker at seat bolt to lift.
on scale 1-10 (10=hard), this is a 4.
Wayne
richard bartlett
04-06-2010 11:30:37
hi mike doubt i can help much but check oil level first, then if the dexta has a hydraulic service, check the service button (under the seat) is pushed in as when out this will stop the lift arms working, check/change filter. hope its that simple! i tend to use Agriline for most parts and i wouldnt think your hyd. pump is that rare that they couldnt help. good luck! Richard.
