Yesterday's Tractor Co.
Shop Now View Cart
Fordson Tractors Discussion Forum
hydraulic service
richard bartlett
03-14-2010 14:47:08
just afuture thought for my major, she's 1955 born with no hydraulic service, ie trailer tipping or log splitter. can i retro fit a service valve? or does it get complicated or expensive?
kenneth armour
03-15-2010 09:15:34
 Re: hydraulic service in reply to richard bartlett, 03-14-2010 14:47:08
Mine (1961 FSM)has a diverter valve on the top of the hydraulic cover, with a knob that when pulled out isolates the rear lift arms and then sends fludid out the port to the spool valve that operates the hydraulic rams for the loader.
Return oil goes back to diff. Return hose is plumbed into oil fill cover at back of diff.
Did find diverter valves for the Massey Ferguson 135 and 178 on Ebay, but have not come across one for the major.
SPARTEX may be able to help.
There is a port untop the hydraulic cover that you could plumb into and operate a spool valve and hydraulic ram, only down side is without diverter valve your release valve is constantly working as your rear arms will be activated and the release valve will come into play.
Hope this helps.
Kenneth Armour
03-15-2010 00:06:30
my major has a hydraulic hose coming off the 3 point valve on the left side, it works after the lift arms are all the way up then the oil pressure goes to the hose, you can plum in a spool valve and wire the 3 point lever in the raise position and then the spool valve will work, i have no idea what kind of pressure they have
