Ad Hickley
New User
I have an ongoing problem starting my 1939 Fordson Standard N. Fuel is getting to inlet manifold but is not being drawn into cylinders: it gets sprayed out of the little valves underneath the manifold as the engine is turned over.
Taking out the plugs and priming the cylinders with petrol almost always works and the tractor runs fine once it has started (although restarting once hot is a bit of a problem!) so it doesn't seem to be a compression problem. Probably.
Any ideas as to what the problem might be? Thanks in advance for any help.
