Galen ishman
Hello Folks... I am sure someone here can help me.. I am trying to install a Lucas C40 (2 pole) generator and a Lucas 6 pole voltage regulator on a Super major tractor.. This is suppose to be the correct combination and matched set... the problem is that the British Nomenclature is apparently different as far as wiring goes.. My first question is is this tractor suppose to be positive or negative ground??? Secondly.. the markings on the regulator"s 6 terminals are as follows: E-D-WL-F-B+ & B+.... since I have no wiring to go by at all I must wire all from scratch... It is very hard to find any reference material on the net about this so I came here to the real experts! Thanks !!!
