Jack's Digger
New User
Will take some time to learn how to operate the backhoe smoothly....
Couple of questions. Hydraulic fluid resivior has water in it (oil is milky looking.) Is it good enough just to change the fluid in the resivior or do I need to purge all fluid out from all the hydraulic cylinders?
kind of a big leak from between the transmission and differential. I know that is a hard fix, but had a crazy idea to catch the fluid in a wired on pan and re-use it until I can split the cases and fix it right. Think that might work for a while?
Thank you.
Thank you.
