fordson major hydraulic pump
jeremy carty
New User
i was just given a free fordson major. The 3 point hitch arms have been removed and the pto shaft has been cut off. i have found a tractor for parts. where is the hydraulic pump located? there isn't anything attached to the gear on the pto on the inside, what should be there? i have ordered a manual but is hasn't showed up yet.
The hydraulic pump is driven off the gear on the PTO shaft. I can scan a couple of pages out of my shop manual, if it will help any.
The pump has been removed! i found a used one locally though. Thanks for responding. My manual finally showed up so i should be able to figure everything out now. thanks again.
