Pto gearbox
Vélite
New User
Hi, i'm looking for the gearbox that, mounted on the pto of my Power major permits to disengage the pto without stopping the hydraulic pump.
Where can I find it new or used?
Thanks!
Hi,
Its called a raised PTO. I bought one on eBay a couple of years ago for $100. Sometimes you get lucky if you watch eBay a lot. If you buy one, make sure that the driveshaft comes with it, its not the same as the standard PTO. You will also need the mounting bolts, because one of them is the shift rail.
