Super Major clutch spindle leak
Angus
New User
I've a 1961 Super Major which has a significant leak from around the clutch spindle where it goes into the gearbox housing. The previous owner apparently replaced the original seal with 2 o-rings which he carefully measured (apparently the replacement o-rings weren't as thick so he put 2 in). This doesn't seem to have worked as its leaking badly again. Is it possible to get the proper seal from somewhere? Also any advice on doing the job appreciated. Thanks. Angus.
Is this the arm near the GB oil filler. can't imagine why clutch components go into the gearbox. my 62 has a shaft there but only as an anchor point and is part of the housing.
