Fordson Tractors Discussion Forum
Fordson Major oil seals
Timo Haveri
07-11-2005 08:29:52
Could someone tell me the dimensions of the oil seal in the PTO engaging lever in a 1955 Fordson Major Diesel? I could measure the inside diameter from the axle but its hard to measure the outside diameter. Is the seal just a common oil seal ("lip" and a spring) or is there some kind of special seal used? Also, what else I need/should
replace of fix when I open the cover of the PTO engaging lever?
I would also appreciate the dimensions of the belt pulley oil seal and the steering box seal.
I"m currently changing all the seals that are leaking oil outside the tractor. When I"m at it, are there any seals inside the tractor that should need attention after 50 years (probably all of them) and are easy to reach? I"m not going to do any major repairs (splitting the tractor for example). I"m just thinking that did I miss anything. I"ve changed the brake axle and the pedal axle seals along with the PTO shaft seal and I"m going to change the rear axle seals as well. The crankshaft seals doesn"t seem to be leaking so I"m letting them be for the time being.
