PonyMan-VA
New User
Ive got an intermittent issue with my 860 that Im at a loss with. The engine will be running fine for 10-15 minutes, then out of the blue itll hiccup and start running rough, missing, smoking (black smoke), backfires and loses all power. After a few minutes itll hiccup again and then go back to running smooth. Then a few minutes later its back to running rough with no power and so on. Its almost like its losing its timing and then finding it again. Carbs been rebuilt and adjusted. Timing is good (when running smooth) and Ive got spark at all 4 plugs. Checked the fuel flow and there doesnt seem to be a problem there. Im kinda at a loss here, about the only thing I havent done is pull the Breaker Plate off to check the internal weights and springs of the Distributor. Could this be the issue?
Any thoughts or ideas would be greatly appreciated.
