851 PTO lever stuck
Fargo
Hi. Any thoughts on this? Always garaged so not rusted. Worked when I bought it I just do not use the PTO and now it does not move. Tried to work it but any harder and I will break it. Thanks!!!
(quoted from post at 03:47:08 05/30/22) Hi. Any thoughts on this? Always garaged so not rusted. Worked when I bought it I just do not use the PTO and now it does not move. Tried to work it but any harder and I will break it. Thanks!!!
Since I had the shop manual out. Not much to it. The pto shaft has a slide coupling.
This post was edited by Tom in Mo. on 05/30/2022 at 04:07 am.
does pto shaft turn freely when tractor is off and its turned off? Have someone turn the shaft while you try to engage it. usually because the shaft is damaged and twisted...
(quoted from post at 16:40:49 06/01/22) OP didn't reference this, but doesn't engaging the pto require the clutch?
With the engine running and no load attached to the PTO it can engage without the clutch with a grinding of the gears. Not recommended.
