Jamie in NC
I went to hook up my auger today to the 860 and I couldnt get the bit off the ground with the lift lever at full raise. I have a 1954 NAA that I use this same auger on regularly and was dumbfounded. I had noticed that the newly acquired 860 wouldnt raise implements as high as my NAA, so with both of them side by side, I started looking at each. The arm from the top housing of the 860 was raised just as high as the NAA. Nothing looked different. I started measuring and noticed that the lift rods (#1)and leveling box was different between them. The 860s rod and leveling box were 25 and the NAA is 20. I swapped them and now the auger lifts off the ground. Does anyone know what the correct rod and leveling box length is for the 860 and may have any other suggestions?
This post was edited by Jamie in NC on 11/11/2021 at 06:50 pm.
