Josh Tallent
Hope everybody had a good Fourth.
I have an electrical problem I was hoping I could get some advice on: my 860 isn't charging the battery and I don't know why. The tractor is 6V positive ground. If I recall, the battery wasn't charging when I got the machine seven or eight years ago; I replaced the voltage regulator with a new one from Brillman. It charged for a while, then got sort of intermittent. I finally had the OEM generator rebuilt at a reputable local shop last fall. I remember being in a rush the day I got the generator back from the shop and I don't recall whether I polarized it or not -- it's possible I forgot. Anyway it charged for a while, then started not charging on startup but coming on after running for a bit (like fifteen minutes to half an hour). Now it just doesn't charge at all. I put in a new wiring harness this weekend, but no change. Pretty sure it's wired right (followed the schematic in the shop manual). The battery is about four years old if it matters.
Anyway the tractor starts easy and runs great; just can't get the battery to charge. Is it the voltage regulator again? Maybe I fried it inadvertently. What should I do/test to get this resolved? Thanks in advance for the help!
