860 hydraulics have slow internal leak
When I shut off my 860 engine, the 860 hydraulics slowly lower their load to the ground. No external leak, so it must be internal. I have replaced all the O rings in the accessory and transmission covers, and put a new O ring on the ram cylinder.
Where else could the slow leak be? Your experience is appreciated, thank you.
All implements should be lowered to ground when not in use. Since all orings/seals been replaced the next place I would look is control valve. Over the years oil will wear the sharp edges of spool and bushing.
