Well, I hooked up the hoses guessing which went where. I didn?t do real bad. When you turn the wheel left both cylinder's push out. When I turn the wheel right both pull back in.
So, it looks like I only have to interchange 2.
I?ve included 2 pics of the hoses. (and 1 progress pic).
On the left side of the column valve the the top front port is hooked up to the inside port on the cylinder. The bottom back port is hooked up to the outside port on the cylinder.
On the right side of the column valve the bottom front port is hooked up to the inside cylinder port. The top back is hooked up to the outside cylinder port.
My idea is to interchange the 2 going to the left cylinder.
Any comments on this???
sorry the pics are on thier side, I tried to twist them.
