I inherited a tractor with a property I bought and have been going Over what it needs to keep going. Among them was a $250 battery, the old owner said that the alternator is not wired to charge the battery, and had a car battery in it on a charger. I put the 75 amp battery in and have used it occasionally for things, and am worried about killing the battery. It has a 3 wire alternator, and I looked at Where some of the wires go but not extensively since I ve been trying to find with no luck a wiring diagram for this model I am not 100% on the year, neither was he as it was his dads. The old owner cut everything to lights, no toggles for lights, no keyed ignition. It operates on a push button start, which I have to wait for the thing to catch then let it rip. Secondly the wires from the alternator run to a voltage regulator that has a harness with 3 pins coming out but nothing connected to them no idea if it s even good. It has a kill switch toggle which has saved me a couple times because the butteryfly clip that connects the throttle just loves to pop off the ball, it s now wired together even with a new butterfly clip. All that aside I really need the alternator to be charging the battery.
