I removed the hyd. sump plate to do a simple reseal. Well now, there is a
little nubin sticking up with an o ring on it. The nubin moves up and
down a small amount if pushed from the opposite side of the plate. The
end is chewed up. I am guessing from being hit with rocks maybe.
The gasket (messicks $25.00) was glued very tight to the plate. It was
more than just paper.
What is actually happening here? Is this a moisture drain? Is the nubin
supposed to move up and down?
Can I just smear black silicone all over everything and bolt the plate
back up?
Pics showing both sides of the plate and the nubin down flat against the
plate as well as lifted when pushed from opposite side.
back up?
