1958 ford 641 workmaster
Unclegoob
New User
Fist off I don't know any thing about tractors just bought a 641 workmaster.is there any common problems with them that I should look for? Also it has the 6 volt pos.ground.I would like to change it to 12 volt,what is the pros and cons to this and also I am confused as to the pos.ground set up (never had anything but neg.ground)would also like to change to neg ground.what would be the best route to do both thanks for any help.PS to show you how lost I am the battery ran down and I ask a guy how do you charge the battery since it's pos.ground he said to put the pos (red)cable on the neg post of the battery and the neg (black) cable on the pos post and I had to buy a 6 volt charger so I hook it up and it said cables hooked up wrong luckily I found this site and got it charged up thanks for that
You must have asked the wrong person. One never hooks a positive to a negative or vice versa. NEVER!
I don't recommend changing to a 12V system, but if you're determined, install a 12V battery and a 1 wire 12V alternator. Hook the ground cable to the negative post. You'll need to change light bulbs and coil or place a resister in the ignition circuit.
Most all 6 volt systems back in the days of your tractor were positive ground,
Thanks I also went to Google and asked how
to charge a 6 volt pos ground battery and
it said to hook the black cable to the neg
post and the red cable to a ground some
bad info out there
That is actually the correct procedure.
The positive cable (usually red on a charger) gets hooked to the ground.
The black cable gets hooked to the negative post on the battery.
Keith
