Here is some background about the Ford 4000
Year: 1967
Fuel: gas
Number of cylinder: 3
About two weeks ago I replaced the water
pump & lines because a leak occured at the
bearing/gasket. While I had everything
taken parts I degreased & power washed the
outside of the engine. Wow the amount of
junk on this engine. Buttoned everything
back up and my work seemed good until some
smoke was occuring on the left side of the
engine. My original guess was a couple of
drops of oil were hitting the exhaust pipe.
After bush hogging 5 acres the engine
started to smoke more. It was also +90F
outside. After I finished I check the
coolant and it seemed full. Fast Forwards
to today and I needed to bush hog 1/2 acre.
From the start the engines smoked a lot. I
only made 1 lap and stopped the tractor. An
hour later I check the radiator and it was
completely empty. So I filled it back up
with 50/50 and did two more lap. I noticed
the tractor was loosing power, smoking even
more and a metal sound from the engine.
Thinking it could be a big problem I parked
the tractor and made a quick video to show
you'll. What do you think is wrong with my
tractor?
Year: 1967
Fuel: gas
tractor?
