Bern provided the original high quality pictures so thanks to him I was able to modify them with this as the end result.
Key Code says it's for the 2600, 3600, 4100 & 4600 --- Less Straddle Mount Cab.
Pictures lose resolution when posted to the board so use the link at the bottom of this post to get the high quality pictures. The ones showing on here are just to give you an idea what to expect.
First I cropped and oriented the 2 originals below:
Problem was when printing the background was too dark so using several programs I managed to get it to this.
Prints a LOT better. If printing in Windows select the 2 halves (Left & Right sides) > Right click > Print, clear the box at the bottom that says "Fit picture to frame" leave the right on full page photo. Set resolution to what you want I used 1200dpi.
That will print a 2 page diagram that can be trimmed and taped together if you want.
For the key code page select it along with the others OR by itself and do the same but a lower resolution works fine.
If you made it this far I suspect you want the link to download them so they are ALL at this link:
https://www.dropbox.com/sh/tpg0ls6pum4cdwk/AADv0g4rblJ3cghRvanhzFFVa?dl=0
Thanks again to Bern
Enjoy
8)
Enjoy
8)
