1974 ford 3000 hydaulic problem
Ben E
New User
Last week my tractors hydraulic pump started leaking. So i ordered a repair kit and put new gaskets in it. It doesnt leak now. As i order that repair kit, I also ordered rear lift repair kit because the rear arms would want to corrections (hiccups) (what the repair manual called it). I pulled it apart and found the rear pressure valve on the return filter apart. The c clip came off. So i brought a new one and put it back together. I put new o rings into the rear cylinder and remote for the front loader. It worked for 10mins then stop working when i moved it from my neighbors to my house. I saw that the remote for the front loader was leaking because i was missing a o ring. Well that didnt fix it. So i checked all o rings again multiple times, all o rings are okay. The frontloader sometimes raises but very very slowly. Also were do i test only the hydraulic pump pressure, At the flow control? Im really frustrated. I dont know where else to go from here. Thanks for the( sorry for such a long story, thought the more info, the better).
