So I have a hole on the high side of the hydraulic line in the bell housing area and I have found the replacement lines (both high and low)
and plan to pull the transmission and put it on the work bench and replace the lines. Has anyone done this and if so how is the best way to
go about replacing them. It looks like they are pressed into/through the transmission.
I have already split the tractor in the front (had to just to find the leak) and I am assuming I have to split it in the back and remove the
transmission to replace the lines. I really would like to know the best process for removal/installation of the lines.
If anyone has any advice or has done these before I'd really appreciate any information you can tell me as this is the first time I have had
to do it.
to do it.
